Is our pool sloping too much?
Windylou
235
Groveton, Tx
Him indoors is adamant the wood will rot. I must admit we had some treated decking in the earth and it was pretty much rotted 2/3 years later...
He wants to put concrete down instead of the slabs next time we empty it...
Goodness this is a flippin nightmare 😪😪😪
Thank you everyone for your help
I’m really surprised that it rotted like that so soon. Maybe it wasn’t treated well? You can also order the pressure treating chemical to do yourself, but that’s more money & more time. Mine are good. They are in great shape & ive even had a couple of huge hiccups that have left them soaking in water for quite awhile. Once for about 2 weeks & once for a couple months, I suspect, but I’m not positive, it was winter & I rarely go out there then. I plan to upgrade to an XTR next year & I plan to replace them at that time just bc it is wood & it won’t last forever. But I want this next pool to.lol
Reactions: Jackie G
kellyfair
3,615
Tampa, FL
I think it also depends on climate. Wood rots pretty fast here due to heat and ridiculous humidity. But look at it this way - if you use PT wood and it only lasts a few years, that’s a heck of a lot longer than the pavers lasted.
Reactions: Jackie G
daisylubob
Active member
Jun 1, 2020
30
Michigan
Reading thru this post, this is the 1st I have heard of using PT lumber instead of pavers. Why is this recommended for rectangular and not round pools?
Jackie G
122
Kent
Yes very true. Its a case of convincing him now 🙄
Jackie G
122
Kent
untreated wood would definitely rot out in two or three years. Pressure treated wood (the green stuff) won't. The treatment helps keep it from rotting. How do your think they get telephones poles to last for years? If he wants to pour a concrete slab, even better.
Yeah, not liking the idea of concrete simply because it feels a bit more permanent and we have neighbours who complained and i ahd to show it was a temporary structure 🙄🙄
Jackie G
122
Kent
Round pools have inherently better stability due to its shape. Oval pool have longer straight runs where bowing can happen. :cheers:
Perhaps we get a round one next time. Do they take up more space you think? I know it probably sounds a silly question but i
Jackie G
122
Kent
If you’re against using PT, just pour concrete footings in the areas where the legs sit. No need to pour an entire concrete pad.
Yes, i think thats what he may have been thinking to do. Easier to get rid too in case of moany neighbours 😁😁
Jackie G
122
Kent
Very true.. thank you 😊
Jackie G
122
Kent
Yes, I'm not sure you can class decking as being pressure treated in quite the same way can you? That is what rotted as we used some old decking to box in an area for a border
Jackie G
122
Kent
I just can't resist it... I have been staring at the title of this thread for over a month and I just can not let such a wonderful set up line go to waste...
No, I don't think your pool is sloping too much... otherwise the swimmers would fall out.
:mrgreen:
Ok ok, have to admit, I chuckled at that one...🤣
Windylou
235
Groveton, Tx
I’m not really sure what you mean. Decking is either PT wood or composite. Composite certainly wouldn’t rot & PT wood should last 15-20 years with just average maintenance. Did you purchase that wood new?
Jackie G
122
Kent
Oops, only just seen this. No, it wasnt new, we inherited it with the house. It was decking, we used it for making a box in the earth and it rotted really quickly. I
Brett S
720
Orlando
It’s also worth noting that there are several ‘classes’ of pressure treated wood. There is just regular pressure treated wood, which is designed to withstand rain and weather and such. Then there is also ground contact pressure treated wood, which as the name implies is designed to be in contact with the ground. I wouldn’t be surprised if the decking was not ground contact rated.
Jackie G
122
Kent
Yes good point, thank you!
mac1911
53
plymouth
Been working on my pool spot for years, each increase in size I get it more level. If you dont know whats under your spot it can “sink” over time. For example if you dont know there was a old tree stump under some earth as it decays it will sink.
also always take away from the high side dont try to build up low side . A laser level is a good thing to borrow/rent. Works well for leveling the ground and the pool frame. 1/2” or less at any point this year!E67AF144-02AB-4B4A-915B-D69F10B2F87A.jpeg
