Yeah, so it sounds like my options are:Using the numbers in this thread, that means currently for 8 hrs, the pump is costing you $3.12 per day. Augmenting the generator with liquid might add $1-3 per day (wild guess). Going with a VS, using the above 24/7 would be $1.32 per day - and give you enough Cl to not go green.
Perhaps $400-900 per pool season to offset the cost of the new pump, until you hit break even.
1. Replace salt cell with one that can handle my pool size w/ the same pump and run 8 hrs/day. Cost: whatever it costs for the salt cell and labor to replace (or, free if I'm able to convince the pool guy since he messed up?)
2. Don't replace anything, continue running at 8 hr/day, supplement with liquid chlorine. Cost: an extra $1-3/day for chlorine (depending how much I can find it for).
3. Replace pump with VS pump so I can run 24 hr/day keeping the same salt cell. Cost: whatever the cost would be for the VS pump and installation, then assuming I'd get similar wattage as ajw22 mentioned above I'd save ~$60/month.
4. Replace the salt cell AND pump with a VS. Cost: parts and installation for both salt cell and VS pump, then save ~$60/month compared to now in electricity. Or more than $60/month, since with a bigger salt cell I may not need to run the pump 24/7. (Or - salt cell is free since pool guy messed up
So it really comes down to how much a salt cell and/or VS pump would cost me. And also what the pool guy is willing to do. I'll have to do some research on that.
A few remaining questions:
I may be ignorant, but the salt cell looks super easy to swap out (I remove it to inspect it...) - is swapping it out for a different one really that easy? Seems like it's something I can easily do myself.
If I change the salt cell, can I still keep the same controller box (the AquaRite 900)?
Haven't looked too much at the pump, probably not as easy as changing out the salt cell - but is that also something relatively easy that I could do myself?
