So I'm really impressed with my Intelliflo VSF pump. I run it 6 hours a day at 1600rpm which the pump tells me yields 25 gpm using 240 watts per hour. For my 14000 gallon pool that means I have a daily turnover rate of 0.64. For a full month this adds up to 42 kWh which costs me $4 per month. I'm happy
But since i negotiated a bunch of pipe size upgrades from my PB and I love stats and data, I wonder if my plumbing is just average or if the upgrades paid off. So I thought I would post my numbers and it would be cool to compare to others.
Pool Piping:
- Suction: 2 skimmers - 2.5", 1 main drain 3" (75 % closed off)
- Returns: 2.5" to the closets corner of the pool and then 2" loop around the pool
- approx 40 ft from pump to pool edge with 2 x 45 elbows
- Equipment pad: all 2" Schedule 40 PVC
Two anecdotes, that surprised me where I'm curious if anybody has experienced the same:
1) When i go to the full 3450 and then back down to the lower rpms, the gpm increase by about 1-2. At first I thought it was just a random inaccuracy, but I can repeat it every time again. Not sure if the high speed flushes out the pipe somehow to allow more flow at a lower speed afterwards?
2) When I cleaned out my filter for the first time a ton of junk came out. However, for all speeds except the 3450 speed the filter PSI only decreased by about 1 and the pump GPM only increased by about 1gpm and after 3 days I was back where it was before cleaning. Does this mean dirty filters don't really make a big difference on a VS pump? Or is my plumbing somewhere a bigger bottleneck than the filter?
RPM | GPM | Cartridge Filter PSI | Pump PSI | Watt |
1000 | 4 | 1 | 3 | 56 |
1200 | 9 | 3 | 4 | 88 |
1400 | 16 | 5 | 6 | 149 |
1600 | 25 | 6 | 8 | 245 |
2000 | 43 | 10 | 12 | 505 |
2500 | 58 | 15 | 19 | 991 |
3450 | 82 | 24 | 36 | 2549 |
Pool Piping:
