mguzzy
As you can see in the attached pic, nothing is attached to the Com Port you described.
Could it be this simple: I get the proper cable, plug it into the Pump Com Port and a matching port inside the control center? Meaning once it is attached, it will do the job and not need some sort of programming?
Reason i ask, knowing the installing dealer, they will push back on making it right. I will try them in the morning, but fully expect to get the "that's they way we do all of them - can't believe anything you read on the Internet..."
And if I can do it myself, where to source and find proper part number?
