I have an Intellichlor IC-60 that is in it's second year of life and was working well until recently. Earlier this season, I was getting a "low salt" warning consistently where it was reading about 2800 ppm. Measurement with a separate calibrated salinity meter was reading 3600-3700 ppm at the same time. The Intellichlor reading kept dipping into the 2600 ppm range where it would shut off chlorine production. OK, so from reading TFP forums, I suspected that the thermistor in my flow sensor was failing. I looked into the wires leading from my flow sensor to my IC-60; It is a 3-wire arrangement with a shared ground, so I cut the white wire from the thermistor leading the IC-60 to use a default temperature in its calculation of salinity. That worked really well and I had chlorine production for several weeks.
The real problem started about a week ago, when my IC-60 showed no lights at all and no response to button presses. I suspected a dead fuse in the Power Center, but guess what??? On opening the Power Center, the green power light is on and a voltmeter confirms that it is producing 24 volts (on the low side, but the manual does give a normal operating output voltage of 22-36 v). I'm using liquid chlorine via Stenner pump in the meantime, but am I screwed here?
Is there anything else I can do to troubleshoot this or is it just dead?
Is this how it is with Intellichlor products? They are way overpriced and fail after a year or 2. I had only 20% of its lifetime used before it failed. Did my cutting the thermistor wire contribute in any way?
PC
PC
