Moved from here.
I'm not sure if I should start a new thread or just continue this one. The latter is generally preferred on most forums, to cut down on searches, so I'll add here until a mod directs otherwise.
Like the OP "I" have an IC40 manufactured in 2014, perhaps retrofitted to a pool installed in 2012. As I am not the original owner I can't say for sure. What I can say is that I'm not sure that the SWG is working. The lights indicate only 20% lifetime used, perhaps 3000 hours but that seems way too low. Then again I have no data on how often the pool was used prior to it changing owners this season.
When the pool was opened (May 15) I inspected the plates and they looked clean. An acid bath produced little bubbling action so I quit that action after a few minutes. Just today I had an opportunity to inspect again and the plates look exactly the same, no flakes. Should I have seen some accumulated "stuff" ? Maybe not, please read on.
Upon opening the pool the SWG operation was erratic with a low salt condition often noted. Checking the salt level (via store and intellichlor diags) showed it a bit on the low side, 2700 ppm. I added the salt needed and it was still erratic. I finally chased this down to a bad thermistor in the unit. For the time being I've bypassed that with a 10k fixed resistor and the unit now runs w/o issue. What I never seem to measure is any chlorine in the pool no matter how long it's been running (initially 20 hrs/day and now 24) nor it's setting (60%, now 100%). The result is presently a green pool, in the process of being recovered, where a week+ ago it looked and measured fine.
So my question is ... Is there some good way to tell if this unit is still working or not ? All the lights are green, the salt is at 3400 ppm and the unit says flow is OK. Can I measure some electrical parameter, current draw for example ? How much chlorine should there be, given the aforementioned setting, in a 27 kgal pool ?
I will mention that the water had tested as balanced with an LSI of 0.0 - 0.1 from 2 different pool agencies. I mention 2 because the installer had been reporting the CYA as 80 and progressing to 125 after using the dichlor shock to get the water good (immediately after opening). Yet my test strips and liquid tests had indicated a level more like 30 ppm. So I went to another tester who confirmed 24 ppm. FWIW the relevant numbers a week ago were :
pH = 7.1
TA = 119
Calcium Hardness = 268
CYA = 24
Salt = 3400 ppm
And 0 levels for copper, iron, etc.
As I am trying to ungreen (algae plus pine pollen plus party) it might be a few days before I can measure chlorine level due to the SWG all by itself but I'd appreciate all answers and opinions as to whether this unit is "pining for the fyords". Also is it necessary to regularly add chlorine, or to shock, a SWG equipped pool ? This is all new to me.
pH = 7.1
TA = 119
CYA = 24
Salt = 3400 ppm
