- Mar 15, 2014
- 65
- Vinyl
- Hayward Aqua Rite (T-15)
My Max-E-Therm heater is 10 years old and was working fine when I last used it in May, but I have reason to believe it may be adding metals to my water, which I assume means it may not be so healthy on the inside. This relates back to a question I posted in July about my water turning green after I added chlorine. The answers all pointed to metals in my water, and my heater as a possible source of those metals. I checked and found, even though I hadn't used the heater in over a month, I was still running my water through the heater. I rerouted the return to bypass the heater for the rest of the summer, but now it's time to crank up the heater again.
Finally my questions-- Is it safe to assume my heater's innards are rusting? If it is rusty does that mean it's on it's last leg, and will soon need repair, or replacement? After the problems I had this summer, I don't want to add more metals to my water, so can it be cleaned, or flushed, or anything done to fix it? Who does maintenance or repairs for pool heaters, an HVAC person?
