- Aug 23, 2011
- 90
- Plaster
- CircuPool RJ-60 Plus
Recently installed a variable speed pump. I have 2 skimmers, 1 has the creepy crawly in it and the other is open, but with this new pump, if I have both open, the creepy doesn't have enough power to move unless I have the pump on a higher speed. When on the lower speeds (2400 or lower) it doesn't even skim. With the old 1 speed pump it worked fine.
The question is If I plug one of the drains and just use one skimmer will that cause the pump to work harder and lower it's lifespan? Plumbing is 2" 60sqft DE and its a 2hp B&D pump. Pool is roughly 50' x 25'
