Hi, I want to give a quick background on my situation here. Last week we got algae outbreak with high CYA, drained the water, and managed to bring down CYA to 50. I have followed the SLAM process and thankfully I have never seen my water being this crystal blue clear since we have the pool. We checked every day and no visible yellow spots in the pool anymore.
I have been testing chlorine levels every day and what shocked me was yesterday it was around 2 ppm so I added chlorine to bring it up to 5ppm, then today I tested it's like 0.5. So is it normal to lose chlorine this fast? Although keep in mind that Texas has been experiencing a heat wave for 2 weeks now (high 90). I tested others using my Taylor kit and everything seems within range.
My readings
CYA - 50
TA - 120
PH - 7.9 (should I add acid to bring down to 7.6? I added last week but somehow it went up again)
CA - 180 (I plan to increase this once I have everything else in balance)
TC/FC - 0.5/0.5
Please advise here on what you think would cause this. Maybe it's just being too hot here and it's normal to lose that much chlorine every day?
My readings
CYA - 50
TA - 120
TC/FC - 0.5/0.5
