- May 25, 2018
- 20
- Vinyl
- CircuPool RJ-60 Plus
After some help from you all, I updated some of my valves myself last year and now I need to add in a SWG. I have a Pentair Superflow VS pump and my pool is about 25,000 gallons. Is a Pentair IC30 too small for the pool?
Long story short I've been speaking with two local places. One is a maintenance company I've used in the past (they replaced the pump) and they recommended and quoted me for an IC40 but they neglected to tell me they are having trouble getting one in stock (not surprising in today's environment). The other was recommended by a friend and has a storefront. I bought the valves from the last year and they said IC40 then. I called up the other day and they said they have an IC30 in stock and I should just go with that as the other brand they have that's bigger is a lot more expensive and they have no idea when the IC40 will be in stock. If I went with the IC30 I'd buy it, then I could either install it myself or work with their install team to schedule. It's only a $200 difference (not sure if I can share full prices) between the IC30 and IC40 and I definitely want to do this right.
I'm also not married to getting a Pentair. I can always DIY if needed but I'm not against paying a pro to get it done right and quickly (I'm good but will take 2-3x as long for sure while I double and triple check to make sure I'm doing things right).
Thanks in advance!
Thanks in advance!
