So, it's been 9 days since last post. Been busy...
After the drain and refill due to potential iron. I balanced all chemicals, keeping PH at 7.2 and slowly raising FC to 6.0. some days having a CC of .5CC. All while looking for iron staining to show up on walls. It never did and the water was light aqua to light green/blue. fine green cloud when brushing. So I finally built up the courage to SLAM the pool starting with a PH of 7.2 last Sunday, May 15th. Water and walls turned blue! No iron staining! Even with over 3" of rain and clouds for the last 3 days I maintained SLAM and blue walls and water. Yesterday I even DEEP cleaned the sand filter the first time in over 5 years! It wasn't too bad. PSI increased from 8-12 PSI. There was a bunch of black Cypress tree needles in it. Vacuumed, brushed. CC has been 0 since Wednesday, 2 days ago. I still have a tiny bit of black dead algae on bottom that settles after vacuum and brushing. Still at SLAM level. Another concern I have is that the water in CL cylinder after doing FC test is... the way to best describe...not crystal clear, sort of "cloudy", pale/hint of yellow. Why would this be? Do I still have to worry about high FC and PH levels once SLAM is over regarding possible Iron? What is my next step? PS we will be away for three days and weather should be 85 and partly sunny. Thank you again for all you guidance!
