Hi. This is my first post after following TFP and TFP methods for about 6 years. Always reading and rereading applicable posts. This is very long but trying to get it all out there.
Last year we replaced the vinyl liner. I do not cover pool in winter. I cover it with a leaf net and let the chemicals go. I keep the pump and filter connected and run only when temperatures drop below freezing as I am close to uptown Charlotte, urban, and temps are somewhat mild. We do have trees.
This year I jumped on SLAMMING the pool at the first warm days/start of Covid on March 11th as I knew we would be home and did not want to stare a swap. The SLAM took forever and then I did the Vitamin C test and realized it was iron causing the light green.
March 11, 2020, First test upon opening, light to med green, uncovered over winter
FC Didn't test
CC Didn't test
PH 8.2
TA 60
CH 40
CYA 30
April 19-April 23 Adjusted FC, PH, TA and all chemicals with, Borax, baking soda, muriatic acid and liquid bleach or liquid chlorine, goofed and added too much borax...
April 21
FC 3.0
CC 0
PH 7.5
TA 80
CH 40
CYA 40
April 24- Finally my FC dropped to 1 and all tests balanced and I added Natural Chemistry Stain Free Citric Acid, half the bottle.
April 21
FC 1.0
CC 0
PH 7.2
TA 80
CH Didn't test again, because it's a vinyl liner and TFP has said I don't need to worry about this number being very low. I don't mind balancing this if it effects other numbers!!! ___________
CYA 40
April 25-added another half bottle of Stain Free and polyfil to basket
April 26- FC 0.0
PH 6.7/6.8, added washing soda, vaccuumed and brushed, all iron off walls, working on raising FC to 1
TA 60
April 27- FC 1
PH 6.8 (afterwards added 6 oz. washing soda to increase to 7.1)
TA 80
April28- May 4 Everything good, test results were where they needed to be or heading that way, balanced accordingly
April 30 (approx) 3" rainstorm in and hour , vaccuumed, backwashed
FC 2.0
CC 0.0
PH 7.2
May 4 FC 1.0
PH 7.6-7.8 (high) added 5 ounces Jasco Green Muriatic acid to lower
TA 100
May 5 FC 3.0
PH 7.5
TA 100 highest its been!
added 4 ounce Natural Chemistry Metal Free
May 6 aqua green cast, rained another 1" over an hour
FC 3.0
PH 8.2
(very high!!!) Why?_________ added 5 ounces Jasco Green Muriatic acid to lower
May 7 greener, ughh!
May 8 FC 0
PH 7.6 added 8 ounces Jasco Green Muriatic acid to lower
30 minutes later
FC 1.0 added 12 ounce CL
PH 7.5/7.6
60 minutes later PH 7.5 added 10 ounces Jasco Green Muriatic acid to lower
I did NOT add any Polyquat 60!
May 9- light rain, aqua green, iron suspended in water, again!?!
water crystal clear in glass
11:00 FC 0.0
PH 7.3/7.4 too high for iron, needs to be 7.2 or lower! added 15 ounces Muriatic Acid, 24 ounces CL
TA 80
12:00 FC 1-2.0
PH 7.2
2:00 FC .5 added 20 ounces CL
PH7.2
5:00 FC .5ish added 12 ounces CL
PH7.2
May 10- still green
11:00 FC 0, added 12 ounces CL
PH 7.2
1:00 added 12 ounces CL, backwashed, MAY have gotten lighter green, most likly wishful thinking
8:00 PH 7.2/7.3; added 15 ounces CL
Mother's Day, Read and Read TFP!
May 11(Monday) Today's full test:
Darker green (see picture-entire pool is same color green, black is reflection of trees)
Vitamin test on wall did nothing
Polyfill and filter soc greenish yellow. (see picture)
FC .5
OCLT complete
CC 0
PH 7.5
Why creeping up? Metal Free? last night 7.2/7.3
TA 80/90
CYA 28/30
Weather has been cool, spring like for the last 8 weeks, cold this past week, 40's/60's and luckily have not had an algae bloom. The weather is going to change quick. This week 60, 70s then 80's in seven days.
What is my next step?
Polyquat 60? What specific brand/name? If we go that route.
Keep going with polyfil?
SLAM? complications as a result?
Drain pool half way? We have city water.
Oh!!! the BIG thing I majorly goofed on is the filter has NEVER been DEEP Cleaned!!!! 9+ years! We completely overloooked this and I've been wanting to do was waiting till things were balanced so if we were down for a few days we wouldn't be back at square one! (I have always had sediment on the floor constantly in the wrinkles. I'm thinking this is the cause) Very anxious to do this when things settle down! I have to do when my husband is available so we can fix anything that arises. Hes very able.
Also note we need to replace the rusted out gauge on the filter. I always back washed/rinsed regularly or when I saw the jet pressure was low. We have one just been waiting to add to his honey do list as I handle the pool 100%.
A bottle of the bleach i used was Clorox brand, high concentrate and one bottle splash free (grabbed by mistake) as supplies were low. Currently have 10 gallons of pool essentials Liquid Chlorine.
Currently on hand have a full bottle of Metal free I was going to add weekly as directions say. Added the first 4 ounce maintenance dose. Is that where my problem started? Do I need to add more Metal Free? Next weekly dose should be tomorrow, but I don't want to if we go another route.
Again, What is my next step?
Get Iron out off solution if it is in solution and into polyfil? With Slamming and polyfil? Will that work??? Will PH go out of whack and cause bigger problem?
I am going round and round!! What is the best next step for my specifics?
CH I don't test often or adjust, because it's a vinyl liner and TFP has said I don't need to worry about this number being very low. I don't mind balancing this if it effects other numbers/processes!!! ___________
Okay! I'm going to work for a few hours.
MANY Thanks in advance to the replies sending me in the right direction.
Take2 in Charlotte, NC
FC Didn't test
CC Didn't test
PH 8.2
TA 60
CH 40
CYA 30
April 21
FC 3.0
CC 0
PH 7.5
TA 80
CH 40
CYA 40
April 21
FC 1.0
CC 0
PH 7.2
TA 80
CYA 40
April 26- FC 0.0
TA 60
April 27- FC 1
TA 80
FC 2.0
CC 0.0
PH 7.2
May 4 FC 1.0
TA 100
May 5 FC 3.0
PH 7.5
FC 3.0
PH 8.2
May 8 FC 0
30 minutes later
PH 7.5/7.6
11:00 FC 0.0
TA 80
12:00 FC 1-2.0
PH 7.2
PH7.2
PH7.2
May 10- still green
PH 7.2
FC .5
CC 0
PH 7.5
TA 80/90
CYA 28/30
