Hi All,
I will be setting up our 32 x 16 Ultra Frame pool again, this time close to an existing deck that also has a retaining wall as part of its structure. Since there will not be room to walk around on the side with the retaining wall, I am wondering if there are any clues on the liner bottom that correspond to the top rail -- are the support straps welded on the liner at the same distance from each other as the placement of the upper rails?
I need to know that info because I will be setting up the support braces while the liner is still on the ground, and then raising the rail up to meet the deck. It will be difficult to push the bottom straps for the support braces out once the rail is lifted... there won't be room under there. I hope to have the straps fully extended before lifting the rail in place.
Any help will be appreciated !
David
David
