Hi,
I thought I was pretty clever when I set up our new Intex Ultraframe pool and ditched the propriety pump and filter in favor of a more standard setup (HAYWARD pump, Pacfab filter with glass media).
Now the tables are turned, as I have no obvious way to connect a vacuum hose. The existing Intex connections are hard to get to, as they are fairly close to a retaining wall. The 1-1/2 PVC was routed around a corner and the pump, multi-port valve and filter sit out there.
I have a big enough yard that I could vacuum to waste, but I see no clear way to connect... maybe put a a Tee fitting with a shutoff valve near the pump inlet (and then figure out how to adapt to the hose) ...any other ideas?
David
David
