Intex Saltwater System - Not generating enough chlorine
dmariecaputo
1
Long Island, NY
I have a 16 X 48 Intex pool with a Krystal Klear saltwater system and sand filter/pump system. My pool is in full sun all day and I run the pump 8 hours and the saltwater pump 7 hours. Although all my other chemical levels are fine via the test strips, I consistently have low chlorine levels. I shock weekly and more as needed. Is there a way to determine if my system is working correctly? I started supplementing with chlorine tabs to prevent algae buildup.
mknauss
37,340
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Welcome to the forum!
Your SWCG is creating 4.2 ppm FC per day. That is sufficient for your pool if you do not have algae. I suspect you do.
You need to follow the SLAM Process. To do that, you need a proper test kit. I suggest the TF-100 A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols. Test strips are worthless.
I suggest you read ABC's of Pool Water Chemistry.
