This is how much it has picked up since i turned it loose and a video of it working correctly
Intex auto vacuum at work - YouTube
I finally got to hooking up the hayward 1.5 hp pump.. it seems to be doing well..reading 20psi though on the gauge (i think normal).. The diverter on my testing of two solar domes is reading 12 psi, about 1 psi on the edge of "green" though.
I had to actually close off the return valve, to allow the robot second valve to be full open and have enough power to not get stuck (with the solar diverter going).. kinda surprised that going from 0.5 to 1.5 still had issues with full power to both return ports.. i do have both the suction and the skimmer basket going wide open as well, though i may close off the suction slightly to allow more power to the haywood skimmer port.
The goal in splitting the return into two (with two different valves) was to allow for the robot to run 24/7 on its own.. turning off the primary return, shuts off the circulation.... but yeah, better than nothing.. in the end though, it appears a ring is still left at least from debris from the cover removal.. very outer perimiter, which ill have to vac manually, not a huge deal though, it took care of the brunt of the issue.. i was pretty sure someone else on here was running theirs 24/7 with both valves open, or so i thought.. disappointed at the 1.5 hp hayward + 21" filter.. figured i'd gain quite a bit of power over the 0.5 intex 2100 sand pump.. i cant have both suction ports open either still (one being the hayward skimmer).. not enough suction as before.So why don't you just turn off the second return when running the cleaner? Problem solved.
I built this Frankenvalve from PVC for my Intex robot. By adjusting this valve and the one on the return, I could keep the robot moving and still have circulation in the pool.
