Intex Pool Owners - Corner joints
landoshi123
1
Illinois
Moved from here.
I have a question related to this subject. My 32x16 pool is still filling up, I am about 4" from it being filled, and I noticed that the corner pieces are not inserted the same distance on both sides. Will I have a chance to correct that once the pool is completely filled? Will they be flexible to allow movement of the pool with the water movement?
jseyfert3
1,344
Southern WI
Do you have a picture? Are the tubes latched into the corner pieces?
You won't be able to manually move anything with a full pool.
CT-Steven
81
CT
I have a 9x18 With the rectangular Intex pools the corner pieces float and move in and out of the straight pieces as the pool flexes and pressures are applied.
