Intex pipe to Nano heater help
Aquaman20
4
UK England
Good Morning all, can anyone help with some help I have a Nano heater i wish to attach to my intex pipe see Pics, would anyone know the best way to attach this please , these are quite thick pipes, is there an adaptor I can buy, as it looks like the heater doesn't have a screw three for the pipe has anyone else got the same connected?. thank you
Ideally, you would like to screw the Intex hose fitting right onto the Nano, but the threads or unions may not match. So one option might be to screw on the Nano fitting designed for pipes like pictured below, the connect a hose to the nano by sliding it over and just using a band clamp from the hardware store. That might work for now anyways. Or once you install that pipe adapter to the Nano, attach a small section of pipe then a union to it like the one below, but first make sure it will match perfectly to the Intex connection.
