I have a 15ft Intex metal frame pool - original vinyl liner
Today I found a pin sized hole about 1 1/2 inches below the bottom seam on the bottom layer of the liner (the part that sits on the ground)
I had a hard time finding the answer to this question:
Should I apply the patch on the outside or the inside of the liner? I can easily get to either side as the pool is not filled.
thanks in advance
thanks in advance
