Because you can not have enough Intex conversion builds...
Well after a few set backs, I have the majority of the system plumbed and it is up and running. I included what I used for the intakes as that seems to be a prevalent question. Yes, very over priced but they are standard 1.5". The plumbing as was pointed out to me does have DVW pieces. I have seen/had mixed responses on that. I'll probably redo everything in the fall just to err on the side of caution. When I added the Intex SWG the pressure in the sand filter jumped about 3lbs and I am now at about 18lbs. I will most likely be replacing it for next year as it will be 2 years old. I have an Intex fountain and the pump easily powers it and the filter. I have the standard 1.5" PVC shut offs for the return and on each intake line. There is also one that runs the fountain. I opted to run the shutoffs for the return and fountain on the ground to provide a bit more stability. When I redo the plumbing to fix what I have and replace the hoses I might do the same to the intakes. That will also take the load off of it hanging from the pool.
