I have had an EasySet 15x48 pool (~3700gal) for ~ 5-6 years now with the same 12" intex sand filter pump/saltmaker (system flow rate 1600gph/1280-12,800gal pool size). I am looking to replace it with a separate intex sand filter pump and stand alone - in series - salt maker. My salt maker has not been running for ~ 2 years - cleaning electrodes does not help. This current sand filter does not seem sufficient - never really did but now worse getting older.
I am thinking of upping the size of the intex sand filter to 14" (system flow rate 2150gph/5500-17,200gal pool size) since the intake hose size is the same as well as the outlet hose size . . . so that it is filtering more water/has more suction. Its a really good price right now - cheaper than the smaller pump! Is there anything negative to doing this other than obviously more electricity/costs? I figure I'll be able to run it less hours if it's filtering more water per hour . . . and perhaps my vacuum will work better and may even invest in an auto vacuum.
Thanks, Joanie
Thanks, Joanie
