I have an Intex 8110 (IIRC) that was giving me low salt errors after confirming that the salt level is at 3200 ppm and that the plates are clean. I opened it up and started poking around with a meter and found that the DC voltage coming out of the rectifier and going into the board was low., ~9.3Vdc. The board has "12Vdc in" marked on it, so I assume that its supposed to be 12v +/-. I also measured the AC voltage coming going into the rectifier, and it was low, so it appears to be a bad transformer.
The control board has its own separate AC input from the Intex transformer for power (10.5Vac per the markings on the board), so I left the Intex transformer hooked up to supply the board - voltage from the Intex transformer measured 11V, so that winding appears to be good.
I have a variac - adjustable AC transformer - that I hooked up to the rectifier to supply voltage to the electrolysis cell. I adjusted the input AC going into the rectifier so that I got exactly 12V going into the board and I still get the low salt error. If I crank up the voltage (19~20V) so that I get ~4.5 amps of current going into the rectifier, the "low salt" error goes away and the control board acts normally. I've been running it this way for a couple of days and it appears that I need to bump up the "on" time, as my chlorine is low. Right now, I'm running it 9 hours per day
My question is this - is the higher cell voltage going to cause issues and will it generate chlorine correctly? I'm guessing that the precious metal coatings (MMO) on the Ti plates are wearing off and causing the lower currents and low salt error when I apply only 12V. Anybody know what cell voltages are used on other similar units?
I'll post some pics this evening.
Kevin
Kevin
