Intex Above Ground Pool Bowing Concerns
I also am installing a 12x22x48in Bestway. Mine is also bowing a bit after adding about 8 inches of water. The bowing is not too bad. My question is, how level does the pool have to be? After filling with 8 inches of water, the rectangular/oval pool is two inches deeper on one end of the rectangle. Should I be concerned? Thanks in advance!
Top of the pattern should be good. Do you have an in wall skimmer? If so, I would fill to 1/2 inch from the top of the skimmer. Then watch your pump basket to make sure it stays full. My skimmer is a bit picky. Too full and it doesn’t skim well, too shallow and my pump sucks air to the basket. Watch it and you will figure out your sweet spot.
Enjoy your pool time!!
