Intermatic Timer
Silva1181
194
Houston
I have an Intermatic Dual Timer T10404R which works fine. I decided to move the "on" tripper for the pump to start a bit earlier in the morning. I placed the tripper back and the pump would not turn on automatically two days in a row. I adjusted the tripper with no success of turning on. I then noticed the tripper looked bent (see photo). so I bought a new pack of trippers for the 100 series. The guy at the store said these will work.
Installed the new on tripper and still the pump will not turn on. I managed to get a photo the backside of the dial showing the tripper which looks like it's positioned correctly. I also noticed this morning that the on switch moved slightly to the on position but not enough to turn on the pump. Is there a mechanism on the back side that can get worn out and if yes, can this piece be replaced? With the warmer weather and humidity occuring, I need to make sure the pump turns on while I am at work.
thank you!
Replace the timer mechanism with a T104M.
The timers wear out and the gears no longer have the torque to flip the lever.
Reactions: lotsalemon
This is exactly what happened to me last summer. Swapping out the guts is pretty simple too.
