My intermatic went out and I thought it would be easy to replace as all I’d have to do is unscrew and move the wiring to the same spot however when I first opened it there was a loose wire not connected to anything. As I never took a picture of the wiring before it stopped working I had no idea where it went. I matched up all the wiring were it was before and everything I thought worked but the spa blower has no power at all. Can anyone help me to find out where the white wire should be on the intermatic to get power to the blower to turn on with air? I did attach the before picture showing all the wiring before I switched them out and the white wire is hooked up to nothing kind of in the back Thank you
