I have an OLD (circa 2012) IntelliTouch i9 system.
Equipment :
- Automation : Pentair Intellitouch i9 + Pentair Protocol Adapter (via hard wire to COM Port) + ScreenLogics2
- Controller : In-home Pentair Wall Controller via hard wire to COM Port
- Main Pump Pentair IntellifFlo VS
- Pool Cleaner Booster Pump : Pentair
- Water Feature Booster Pump : Pentair
- Pool Cleaner : Polaris 3900 Sport
- Spa Heater : Pentair MasterTemp 400
- Spa Blower : Air Supply Silencer
- Filter : Sta Rite DE Filter
- Lights : Pentair Pool LED, Pentair Spa LED, low-voltage yard lights
Behavior :
The system is a bit all over the place. Normal scheduled stuff kinda works. Spa mode kicks on as scheduled, Pool pump kicks on as scheduled. However, the Polaris does not come on when it's supposed to.
When I use ScreenLogics on my iPhone here is a break down:
Works:
- Water Feature
- Spa Blower
- Pool Light
- Spa Light
Does not Work:
- Spa Temp last reads 134F, which is ridiculous. However, the hard-wired wall controller shows 65F (which is probably accurate)
- Spa Heater wont Kick on. However, this works if i manually press the button on i9
- Polaris doesn't work. However, this works if i manually press the button on i9
Planned Upgrade :
I've ordered the Pentair IntelliCenter Upgrade Kit (P/N 522046) to update my Automation and hopefully dramatically improve our stability and reliability. The order was placed months ago and seller (ePoolSupply in AZ) says that Pentair is telling them December for delivery
I'm trying to get my current system working well enough to bridge the gap.
Any ideas to help get the system working until i can upgrade would be greatly appreciated. Let me know what other information I can provide to help.
Equipment :
Behavior :
Works:
- Water Feature
- Spa Blower
- Pool Light
- Spa Light
Does not Work:
Planned Upgrade :
