clg,
You said you were pretty "Tech Savvy" so this might be harder for you. It is so simple that you will keeping looking for something complicated to do..
Do you actually have an IntelliTouch 8
and an EasyTouch 4 ? If so, I'm not at all sure if that will be an issue or not... ????
For the
normal install, ScreenLogic communicates with the main Control panel via a 4 wire cable
or a wireless transceiver set. I use the wire because my EasyTouch is just on the other side of the wall from where my computer and router are. Either way, the control panel supplies information to a Protocol Adapter, the heart of the system. The Protocol Adapter speaks "Pentair" on one end and "Ethernet" on the other end. It basically converts the Pentair info into something that the Ethernet understands. The Ethernet end just plugs into your a router or switch and acts like any other Ethernet device. To use it you have to download an App for your PC and Phone.
The PC App works very well for me... the phone, works but as well. I hear there is a new release out, but the feedback on the new release has not been too good so far.
Personally I would not try to program anything until you get ScreenLogic. It is truly about 10 times easier to program using ScreenLogic than it is using the 3" LCD.
I don't have a Spa or Heater, so I'm not really up on the delay, but the manual says the heater cool down period is for 10 minutes and can be set to either enable or disable..
Good luck with your project,
Jim R.
