- Jul 21, 2013
- 65,106
- Plaster
- Pentair Intellichlor IC-60
Override is the wrong term.So you’re saying the temperature is set via intellitouch for a desired set point that overrides the manual button mastertemp set point of 104 ?
104 will be the maximum the MasterTemp will allow the temp to be. If the IntelliTouch does not stop the heater before 104 then the heater thermostat will shut it off.
Up to 104 the IntelliTouch turns the heater on and off as necessary to maintain the heat set in the IntelliTouch.
