I used the IntelliChlor transformer in the ET wired to a relay after the voltage got stepped down to power the acid pump.
I realize this is an old thread now, but I landed here because it sounds like @bdavis466 did exactly what I'm trying to do in commandeering control of the IPH.
I've been scouring Amazon for parts to do this but I always get hesitant before purchasing not knowing if I'm buying the right parts.
Do you mind sharing what you used to tap into the IntelliChlor Power? (I have the IC Power Center, it's not in the ET)
What type of relay did you use? Mechanical or SS?
What did you use to step down the 39V /7.7A DC to 24V/1A DC?
Thanks in advance!
edit: added link to old thread
