I recently had to replace my Intellichlor after it started tripping the small breaker on my Easytouch. I initially had trouble with my new SWG not making enough chlorine, but figured that out with y'all's help (chlorine level was too low to catch up).
Now I have an issue with my IntellipPH. As you probably know, the acid feed goes in before the SWG, an disables (shuts off, stops - whatever the correct verbiage is) the SWG while dispensing acid. When it's done, it reactivates the SWG.
My problem is the last step. recently, the IntelliPH has begun failing to reactivate the SWG after dispensing, leaving my pool without any chlorine being generated from that point forward. When the pool shuts off for the night and comes back on in the morning, the SWG works fine, until the Intellichlor dispenses. It stays that way until I restart the motor.
What's the deal? Which part(s) can I test & how?
