IntellipH stuck in SUPERCHLOR mode
soleen
Active member
May 17, 2023
30
New Hampshire, USA
Pentair Intellichlor IC-40
I have the same problem: IC40 + IntelliPh keep getting stuck in SUPERCHLOR, eventhough I never enable superchlorinate. Has anyone been able to find a solution to this problem? Powercycling main board (Intellicenter) helps to reset everything.
I have this problem every so often. I reset the Intellicenter and it fixes it until the next time. I have applied the burnt connector fix and it doesn't seem to make a difference.
I just make sure to look at the iPh every couple of days as part of my daily pool checks and reset as needed. Might convert to a timed relay cycle one of these days and ditch the iPh controller altogether.
--Jeff
Reactions: soleen
