Hi,
I recently installed a Pentair IntellipH. My troubles started immediately. I ordered the unit from Amazon. Got it in two days and was ready to install it but found that the controller was missing the plug to connect to the pump. Amazon is awesome and sent me a new unit. Two days later, I do the install and all seemed great until I came back from vacation to a pool with a pH of 8. Also noticed that the acid level in the tank was the same as when I left. I hit the manual dispense and nothing happened. I checked the connection to make sure the plug was properly seated and the pump runs. I let go of the plug and the pump stops. I do this a couple times with the same result as before and conclude that connection or plug is bad. So I unplug the cable to inspect the plug and this is what I found:
As you can see the plug and the connector both have metal contacts that are male. I think one needs to be female to get a solid connection. Before I contact Amazon for yet another replacement, can someone please confirm my thinking?
Thanks!
KM
Thanks!
KM
