Hello!
I moved into a house about a year ago with an older pool (built in the 80's). The previous owners upgraded the pump and filter system to Intelliflow with a Sta Rite filter, and added a solar water heater. The pool itself is plaster and about 25,000 gallons. The issue is there is air coming through the pump and bubbling out of the return lines. I've tried everything to diagnose it, and recently had a leak detection company out as I thought it was a leak in the skimmer. However, they determined it is because the old pool has 1 1/4 inch copper pipes and there is an adapter to 2 inch PVC to go into the pump. At higher RPMs this is pulling too much through the skimmer and pulling in air as well. I guess my question is will running the pump with air coming through burn out the pump faster? The old owners just ran it as is, running the pump at 3100 RPM's to the solar water heater, with about 5 inches of air in the pump basket. Will this put additional strain on the pump?
My other question is, does it make sense to look into replacing the pump with a 1 1/4 suction side pipe option, that runs at the same RPM?
Let me know what additional detail I can provide, I'm sure I've missed a bunch.
