So recently started up my new pool. Have 2 IntellifloXF VSFs and 2 VSs.
The GPM readouts I'm seeing from the pumps do not make any sense to me based on the pump curves.
For example, my Spa booster pump is showing approximately 11 psi on a manual gauge on return side - that should be about 23 ft of head right? At 3450 RPM, according to the curve, that should be about 210 GPM. Except, the pump readout is about 85 GPM. In that loop, there is a 3" suction, and a 3" and 2" return line. No filters/heater in that loop.
Filter pump is similar - Filter shows 19 psi at 3450 RPM, so 44 ft of head - that should be about 180 GPM. Nope - pump shows 70 tops. 3" drain suction + 2x 2" skimmer suction and 9x 1.5" returns + 2x 2" returns (each jet individually plumbed).
Are these readouts horribly inaccurate? Or do I have some other problem?
