Hello,
I have a Pentair Intelliflo VSF pump and a Jandy Aqualink automation system (older RS4 recently upgraded with the IQ-30 kit). For the most part everything seems to be running fine, but I do have a question about using the pump's controls. With the automation connected, the pump's display normally says "Display Not Active" and none of the buttons on the pump panel will do anything. OK, I know that's normal, but I'm wondering if at some point I want to use the pump's display and controls, how can I do that? I have been told to just put the system in Service Mode and wait a little while and the display should be usable again, but that's not the case. Short of disconnecting the cable or disconnecting the pump communication using the app, is there any key sequence or something that I can do to temporarily override the automation and use the pump's own controls and display?
Thank you,
Greg
Thank you,
Greg
