My intelliflo VF pump was working great for two full weeks since installed. It primes in no time even after opening the pump. But now it is constantly giving a priming error.
Recently the pump is getting stuck in the priming cycle even though there is no air in the system and the pump is full of water (only a tiny bubble left at the top of the lid.) There is really no need to do any priming but the pump doesn't know it. The pump starts to ramp up, full speed, slows down then starts the cycle again until priming times-out and the pump throws an error. During all these cycles there is flow (as seen at the flow meter) and there is no air in the filter either. If somehow sometimes it manages to get out of the priming cycle it works perfect.
This somehow only happens when the multiport valve is set to filter, if I set the multiport valve to recirculate, rinse, or backwash the pump primes and runs normally. After a recent filter backwash and recharge the issue improved but it is now back to the problem. I already opened the multiport valve but everything looks clear there.
I have tried changing the priming settings but that does not seem to help. if I start the pump on manual with fixed speed it runs perfect too.
Filter pressures are normal under running conditions about 24psi. Filter is Pentair DE FNS60 - multiport valve is pentair high flow.
Any clues out there please? why is the pump getting stuck on priming?
