Another year, another surprise.
Decided to open the pool early this year to give me some time to work on lights and maybe fashion a swim jet in the pool.
Opened over the week and got the pump running 2 days ago for a bit. The DE filter was leaking so I only ran the pump for an hour or so. Yesterday fixed the seal and got it tightened up and added a few gallons of chlorine turned the pump on to run for a few hours to circulate the water, filter and then test the chemistry etc. Pool was clearing nicely.
Pump is a Pentair Intelliflo, unknown age. After about 3 or 4 hours I noticed the pump wasn't running so I went to take a look. Pump looked fine externally. Breaker not tripped. I cycled the power an nothing. When going to look at the pump directly again after cycling the breaker and GFI. The display at first was blank. I moved the conduit going in to the pump just to get a look and the digital display on the control said power failure!. It was getting late so I shut everything down, turned off the breakers and pulled the cover to the block this AM.
Here is a pic of the block...No bueno!
We did have a surge here during a storm a few days ago and the power cycled a number of times, wiped out some stuff at the neighbors hours. but the pump ran just fine for several hours? I did get several "unexplained" shut downs last year early on but during the last several months of the season everything ran flawlessly.
I could have also been something that caused the pump to overwork but I would have thought that would have tripped the fancy breaker that Pentair requires for these. Everything else in the system looks fine. The breaker and wiring at the panel looks great. The heater wiring and control looks just fine.
Wondering if I should try to remove the fried block, run new wire, wire nut the leads and see if the thing will run?
Hopefully it didn't fry the motor but I am not terribly optimistic on that one.
Any thoughts on a reasonable way to proceed would be much appreciated...
Dennis
Dennis
