- Apr 10, 2018
- 5,178
- Plaster
- CircuPool RJ-45
I'm looking for advice on selecting a 24 volt WiFi switch/relay for pool automation. My builder set up my IntelliFlo VS control in an unconventional way. Instead of using the pump control panel to set up timing programs, my system uses two Intermatic timers and two low voltage rocker switches. Each device is routed to an Intellicom II Interface adapter which receives 24 volt voltage from a transformer. The RS-485 data cable is connected between the Interface Adapter and the pump data port. Any one of the four switches will activate the pump at the programmed speed. As unconventional as the wiring is, I've gotten use to it and like not having to bend over my VS control panel to change timers.
I would like to swap the two rocker switches with WiFi relays/switches controlled by an app to allow for setting up timers remotely. The switches need to meet the following criteria:
I can post pics if needed.
Thanks in advance.
- 24 volt (voltage at the switch reads 18 volts)
- Compatible with a dual band (2.4 GHZ/5 GHZ) Google Mesh router
- Have Alexa control
Thanks in advance.
