Hi all,
I have an intelliflow VS pump and a solar heating system controlled by a Pentair SolarTouch. I now plan to install an SWG, and I'm realizing that I should have used a more general controller than the solartouch, which is apparently useless for controlling anything else (although pentair does say that an intellichlor can communicate with the solartouch, I think that it would only come on when the solar is on if it was connected to the solartouch).
So, it seems that now my options are to convert to an EasyTouch or intellitouch that could control the SWG and the solar, or to just put the SWG on a timer. Right now, when the solar is not on, the pump is running at low speed 24hrs, but I'll turn it off at night in the winter, and could just run the SWG during the day all year on a separate timer. I posted a question on the Pentair Intellichlor website, and the answer suggested I could just rely on the Intellichlor timer and flow switch, although I have seen on here the recommendation for a mechanical timer and would go with that.
Given all this, do people think that the automation would be worth it? If I just go with the timer, is there any reason to consider an intellichlor (IC60) over the circupool (RJ-60)? Frankly I am kind of annoyed that the intelliflow pump can't tell the intellichlor when it's on and off. Pentair just seems to purposely compartmentalize everything.
Thank you - any advice would be appreciated, and maybe I'm missing some alternative solution.
Bob
Bob
