Pool readings:
Salt: 3500 (Digital Salinity Tester and pool store)
PH: 7.8, working on it. (test strips and test kit)
My Intellichlor was reading 0 ppm salt. I gave it an acid bath as it had some build-up on it and it started reading closer to the 3,500 ppm. Then it started dropping (as the ph went up) and it's now reading 2,400 and giving me warnings. Chlorine levels in the pool dropped enough that algae began to grow and I had to SLAM it. So I tested Intellichlor by running it just on the spa and the chlorine levels went up but it doesn't produce enough to keep the pool chlorine levels high enough.
Ideas on what's going on? Intellichlor going out? Flow switch going out? I think the unit is 2 years old. Does it somehow need to be reset?
Thanks!
Thanks!
