Andy,
it appears to me you’re CYA is low, which will allow FC to burn off more than is necessary durning the day in direct sun.
Also, what is condition and clarity of your water?
and how did you open, did you SLAM at opening?
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.
www.troublefreepool.com
Sounds to me like something is consuming your chlorine - algae!
check out these resources
There are several items things every pool owner should know about swimming pool water. We share details on the basics of Pool Water Chemistry.
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.
I’d also suggest you fill out your signature, the info will help you and rest of the forum as questions will be minimized when you are requesting assistance from the TFP team, see here:
I personally target CYA of 70 and FC of 7+. I've been away from my pool for over a month now (caring for a family member) and my pool remains clear, free of algae and very swim-able. in fact my beautiful bride was in yesterday - she said it was perfect. I’m kinda able to manage my pool remotely via my nest cam and Pentair ScreenLogic software which allows me to manage pump, HP and most importantly SWG output.
I’m sure some of the TFP experts will chime in here, but the above will get you headed in the right direction.
enjoy..
