Troubleshooting my Pentair IC40 SWG which has constant RED NO FLOW light. Acid cleaning didn't help and there wasn't much buildup anyway. Began to think the flow switch was bad. Found a thread elsewhere that said to short the RED and BLACK wires going to the IC40 to confirm flow switch is bad. Did this and got a GREEN FLOW light. I believe this proves the flow switch is bad. I have a new one on order and it looks simple to replace.
My question is, does anyone know if I can keep the RED/BLACK wires shorted until I receive and install the new flow/temp sensor? I'm thinking this would tell the IC40 to "make chlorine" and I probably wouldn't want to be making chlorine when the pump is in the off cycle right? How about if I run the pump 24/7 with the wires shorted until it get the new switch? Seems like this would be ok but don't want to screw up anything. Thanks to any SWG experts out there who can take the time to weigh in!
