Can I add some intellivalves and automate different modes in my pool? Basically, I like to keep my pump running as long as possible. So in pool mode it's normally around 60 GPM so I can have my bubbles on. I only turn on the deck jets when the kids are in the pool. Instead of constantly walking to the equipment and manually shifting valves then adjusting the pump speed... I'd like to be able to choose b/t different modes. For example...
- mode 1 - pool on, pump at 30 gpm. this would run most of the day. save electricity and no need to aerate the water when we aren't home.
- mode 2 - (existing pool mode) pool on, bubblers on, pump at 60 GPM. this would run when the wife are I are outside relaxing and wanting to hear the water moving
- mode 3 - pool on, deck jets on, pump moving faster to make the deck jets higher, bubblers off, pool return valve reduced to 50% or so.
- mode 4 - (existing spa mode) spa on, pump at full speed. all return water going to spa side
I'm not sure if I can automate this with the click of a button on the app. It would certainly be nice. I have an intellivalve that controls the returns b/t the spa and pool. But the valves after the 'pool' are manual: pool returns, bubblers, & deck jets. I know the first step would be to install and setup intellivalves for these three valves. However, I don't see on my intellicenter app where I would be able to setup these modes.
Intellicenter shows I have a pool & spa. They share an Intelliflo VSF pump. As of now, I can basically toggle b/t pool & spa. Anything else has to be done by manually adjusting the valves then adjusting the pump speed in the Intellicenter app.
Is this all possible or am I dreaming?
