Candurin
- Jun 30, 2017
- 388
- Fiberglass
- Pentair Intellichlor IC-40
Dumb question. Does the Ethernet cable need to go directly from the RPi to the serial com board or can it be networked?
My RPi would be 100’ away from the intellicenter. Luckily, I can run a direct cable, however, I have a second router 20’ away from where the IC will be installed and it would be easier to go IC > router and then from a network switch right next to the RPi to the RPi.
Or, can I remotely connect to the RPi? Hopefully this makes sense?
I can do whatever is needed as equipment won’t be installed for a few more weeks.
