- Jun 18, 2019
- 354
- Plaster
- Pentair Intellichlor IC-60
So I've got an Intellicenter. According to this site, that latest firmware is 1.047: Intellicenter Download
My Intellicenter has 1.040. Using the control panel, I went to Advanced Settings, System, Update and checked for updates there (presumably over Wi-Fi), and it indicated there were no updates. All the Pentair docs cite using the USB port on the front of the panel. So where is this USB port? Do I need to unscrew the cover and get to the electronics? Furthermore, why can't I just get the latest firmware via the online check?
Once I find the USB port, I'll flash it. Are there more precise firmware update instructions. For example, what format should I format the stick? FAT32, exFat I assume are both ok?
Thanks
Thanks
