- Apr 26, 2021
- 83
- Pentair Intellichlor IC-60
I need help with my newly "homeowner installed" pool solar automation.
I have a three way intellivalve between my filter and heater for the solar. I plugged this valve into Valve B and assigned the valve to "Solar". What I thought I read in the manual is if you have two bodies to plug the solar port into valve B...however now I'm thinking about this I do have two bodies, but utilize one pump and automation to switch between the pool and spa.
Originally I did not have a Solar temp sensor, so I put the solar on a schedule off of the "solar feature" I programed. This worked great, at 12-5pm the solar ran. However as the days get shorter and colder, I wanted to have full automation. So last weekend I installed a temp sensor on one of the panels, and plugged the sensor into the solar port in the control board. As well as setup a "solar heater" in the heater section.
When the sensor is 6F hotter than the pool or spa water the "Solar Sun" shows and looks like it should be heating the pool via solar, but the solar feature does not turn on, and the intellivalve remains in the normal operating position.
I need help linking my solar heater to either the solar feature or Solar (B) Valve.
