- May 3, 2014
- 59,322
- Fiberglass
- Pentair Intellichlor IC-40
Marty, I really appreciate your help. Thank you. I'm trying to absorb all this info. According to the manual, when spillover is enabled in configuration, the Aqualogic will automatically run in spillover mode at the start of the programmed pool filtering time. It sounds like this makes it function the same as what I had before the problem (lack of circulation to the spa), which is great.Great. I do believe you then need to schedule it. But one thing at a time.
Thanks for that warning. Here, I have to add acid every week. Maybe I'll try running spillover mode at lowest speed to keep just a trickle overflow and see what happens. I do have to run the system at least 11 hours this time of year...Good to hear. I assume the Spillover function runs for X amount of time? Can you adjust that? Running it continuously will push your pH up.
Jim, it is strange, isn't it? The valve is such that it is not meant to turn beyond 90 left or right (the stop pins you mentioned?) No one has worked on the pool equipment (except me) since originally installed, so the valve may have been defective to begin with, but I wouldn't know, having never touched it till now. And where did all that air came from if water was going down both pipes just fine in the original configuration? I'm stumped. My pool mystery is getting more convoluted.D,
Some valves have stop pins and I can't tell from the pics if you have them or not..
Does not make sense.. The valve is set up to allow water to go down both pipes (handle pointed up).. It should allow you to shut off the left pipe and fully open the right pipe. (Handle pointed right) Or, it should allow you to shut off the right pipe and fully open the left pipe.. (handle pointed to the left)
Maybe someone had the valve apart and did not put it together correctly...
Can't think of any reason it should cause any bubbles as this is a return pipe, not a suction pipe..
I wasn't clear, sorry. The valve should turn exactly as you describe, but I can only turn it 90 to the left. Cannot turn it right at all when starting from the position in the pic. in other words, it will not turn 180 total, only 90.D,
Maybe I just don't understand, but the valve should only turn a total of 180 degrees... From the position in your pic, 90 degrees to the right and then 90 degrees to the left for a total of 180..
Am I just confused???
I plan to take the valve apart. Maybe it just needs cleaning & maintenance. Need to find the time. Thank you so much for your assistance. Will report back, soon, I hope.D,
That does not make sense... If you get a chance, I'd take the valve out and check how it it installed.. I'd do that when in the spa mode and pump off, so that you don't dump a lot of water.
