Question to those who have done the conversion.
With my pool in the original configuration, I would leave it up year-round. At the beginning of summer, I'd pull the plug in the drain and then refill. This season is the second year I have had the insert liner. I used a small submersible pump to drain the pool. I cleaned it. When I went to refill the pool, the liner began to shift and reseat itself. It stretched out the hole around the skimmer. Additionally, water tried to pull the overlap into the pool. I am left to assume that draining and refilling the pool was a mistake.
What do those of you that have done the conversion do each summer to prep your pool? Do you keep the prior year's water? Any tips would be appreciated.
I am either going to have to shift the liner and patch the old holes and then cut new ones, or replace the liner and start over.
