I connected the wire to the pump ran it around the pool connected it in four places. Next plan to run it up to the skimmer, then on to ground the fence. Now where does the wire end? Does it make its way back to the grounding point on the pump to complete the circuit, or does it just end, at the last item wanting to be grounded?
Oh I see what could be done with that info..........as it goes around the back of the pool he could run it out to the fence then back into the pool in a couple of places. That will allow it to go all the way around so it is one big wonky circle.
Thanks Mr B!
Kim![]()
pH has been holding steady at 0.8 and 0.7.
