Hi all,
Just wanted to follow up on my question and attach some updated pics. I’m still not all that familiar with my pool/inground spa mechanical equipment, so hopefully I’m attaching the right types of images.
Issues:
1) My inground spa doesn’t heat and starts draining water to the top of the return jets when I turn it on.
2) The buttons on the heater don’t turn on.
3) Not sure if the heater is incorrectly reading the spa temp at 105F? (please see pic) The water definitely isn't that hot.
Settings:
4) Spa Jets are set to AUTO ON 1
5) Spa Drain set to AUTO ON 2 (the label is fading so I think it says “Spa Drain”)
6) Red heater knob is turned up (I believe that’s the ON position?)
Question:
7) Would an inground spa have its own filter separate from the pool filter? (again, still learning the equipment)
I did confirm that valve knobs turn when I turn the spa on and off. On my pool remote, I turned the manual heat setting to "On." It was set to off before, and I'm not sure which setting is right.
I’m not sure what else to check and do to get the heater working again.
Thanks for any replies!
